Burn,
Based on you orig. question, I only added my comments as I have an '80 C30 also. I would assume that if you never saw a base plate on the exterior of the hull, your strut was made like mine.
So picture this, I first saw water coming from under the fuel tank the same night after the boatyard splashed it. Removed the tank & saw the mudding had a crack where water was seeping in. Upon removal of the mud, Lo-n-behold there was my flange with no firm attachment only, the MUD. To me that is not a "positive" mounting that depends on a glass mound. You have a spinning/harmonic vibrating shaft. Look at the strut from the outside & you only have some glass buildup around the thin narrow strut stem. Does this sound like a positive seal solution?
Thinking it over as it has been years, looking forward, I drilled two diagonal holes thru the baseplate front & back. With the strut dry-fitted in (shaft in place), I marked the hull & drilled. I bolted with brass thrubolts using fender washers on the exterior, I had to cup these somewhat to fit the hull shape. My glass man then encased the strut base & exterior bolting in glass.
I only offered what I found in the chance that you may have the same condition.
Funny, the one thing we both had in common, was that this was detected right after the boatyard splashed your boat. Coincidence, I think knot but, it's your boat hence, it's your choice. Just make sure whatever you decide is better than the original.
Cr
