shaft strut spec
5,802
Do you mean the bore size which is 4" x 1 1/4" ?
Jun 2, 2004
5,802
As you can see in this link there are several factors: http://dahmermarine.com/Struts.htm . Your original strut was one of those at the bottom of this link. Somewhere in "Search" you can find the number I think. You doubtless know that the company went out of business. Interesting that the website remains.
P.S. Found this and another from Sam Lust:
http://forums.hunter.sailboatowners.com/showthread.php?p=122382&highlight=dahmer strut . Might be worth an e-mail or PM to Sam. My strut has the Dahmer part number on the side.
P.S.S. sorry about the 4" guess. I did not know the H30 had the v-strut(see Mark's post following).
Mar 18, 2010
91
O'Day 222 Smith Mountain Lake, VA
Ed is correct...
at least on my 75 H30. Model 2010 is the strut. Note that dimension A is the outside dimension of the cylinder while the inside ( as noted by Ed in his first post ) is 1.25 inches. However, the length of the cylinder is 3" ( 3" cutlass bearing for a 1" shaft is the next tough thing to find. )
I plan on going to my boat this weekend and will measure the V angle then, but ~60* should correct.
So Larry, have you found a source?
