Can I get some feedback on shaft strut movement. Pullout at the end of the season revealed some play in the shaft strut < 1/4" side to side, is this within reason or should the strut be reset? The cutless bearing also show some wear and again shows some movement/play within the strut shaft. I'm looking into the Strut Pro tool to remove and install the bearing, has anyone had good luck using one? Does anyone know how the rudder post is designed to prevent water from entering the hull? This does not seem to be a problem on my boat, but from reading repair manuals, I see examples of a stuffing box around the rudder post to prevent water from entering. I'm just wondering if a coastal cruiser does not merit one?ThanksLarry
