Shaft Size
28
2 t-2 Atlantic City NJ
I have a 1979 hunter 30 ,12 yanmar.I need to replace the Shaft seal I wanted to know the size I need? Thanks
Jun 2, 2004
5,802
Jonny, are you asking about the shaft size or the size of the packing for the stuffing box? One inch is correct for the shaft and I think 1/4" for the packing.
Dec 2, 1999
15,184
I believe that the packing is 3/16" for the 1 inch shaft.
If you are looking for a dripless, you need to know the size of the box it self.
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
Base on both Ed & Steve's comment on packing (both are pretty savy guys) there may be various sizes of packing gland for the 1 inch shaft. On my 1990 H-33.5, I also have a 1 inch bronze shaft, but based on the ID of the packing gland, it takes a 5/16" teflon impregnated flax packing (along with the "Green Teflon Putty" as the middle ring). Thats 3 different packing sizes for the 1 inch shaft. So Jonny, get a micrometer (or dial calipers) and measure the ID of the packing gland, subtract the shaft diameter, and devide by 2 to get the correct packing size. Good luck.
Dec 2, 1999
15,184
You can also contact Hunter Marine. This was posted on their FAQ's page, but I cannot find it any longer.
We just repacked ours and used the 3/16" and it works fine.
