I just replaced my 1978 H30 shaft, it was 1" x 50", and whomever you are getting the shaft from can supply you with the correct flange, just measure across the face of the output flange on the motor and tell them the make and model of the motor and they will match it up. You can measure it in inches but they actually go by metric. Yanmar only uses two different size flanges a smaller 4 inch and a larger one. that should get you what you need.
