Tony Musker
Hi All,I want to fit a PSS dripless shaft seal to the prop shaft on my Capri 26. The shaft is 1 inch diameter and the shaft log is 1.625 inches outside diameter. The PSS comes in either 1.5 inch or 1.75 inch log diameter. Which should I go for? The smaller unit (therefore stretching it slightly over the log) or the larger one (therefore compressing it slightly onto the log)?Thanks,TonyEngland
