John Killian
The local yard is replacing the shaft on my 1982 Hunter 37 Cutter. They called to say that the metal tube that the shaft goes through to exit the hull, (the packing gland is attached to the tube on the inside of the hull), has corrosion and should be replaced. I have never heard of anyone doing this before. Anyone had any experience with this issue. Thanks John Killian
