Don
I have a couple of questions here about my 1982 Hunter 27. I was trying to replace the cutlass bearing with many faild attempts. The yard couldn't even get it out using their tool. So I removed the strut. Now I see the shaft is pretty worn and it needs to be replaced. Question #1 Can I remove the shaft and replace it with out dropping the rudder? Question #2 Does anyone know where I can get a new shaft? Question #3 When I removed the strut, I noticed the two plates on the inside of the hull that the screws go though. I believe thay are bedded. Should I remove these plates and rebed them, or can I just rebed and place the strut?
