I opened up the stuffing box today with the idea of re stuffing, but found quite a lot of gummy build up on the shaft and not much space to work with (see attached photo). As a result I would like to disconnect the prop shaft and remove the nut so that I can clean up the shaft and re pack the box. My question is how difficult is it to detach the shaft and re attach it and will it need to be re aligned. The boat is out of the water and the transmission is Kanzaki Km2p.
Thank you
Tim
Thank you
Tim
