I have a 1979 Hunter 30 with a Yanmar 2GM20. The yard mechanic tells me that the strut is bent and needs to be cut off and straightened. Another mechanic tells me that it looks like it is offset to allow the shaft to be removed since the rudder and skeg would impede the removal if the strut and shaft were straight. I have asked the first mechanic to look at the engine installation to verify that the engine was not installed offset to allow the shaft to be removed without taking off the strut. We pulled the prop and the cutless bearing is slightly worn but not overly ovaled as I would expect if the strut was sreiously bent. I have not noticed any unusual vibration when running the engine prior to hauling the boat.Question: Is the strut and shaft offset on a 79 Hunter 30?Thanks, Tim the Tulman
