I recently had a problem with my 356 prop shaft & keyway & had to be towed in. Marina maintenance reported that the seal (I had a dripless stuffing box put in before the boat was initially commissioned 3 years ago) failed and caused the key to rust out and fail. The boatyard felt that the key was made of low grade material. Anyway, they had to replace the seal, shaft (which got chewed up when they key failed), keyway, fittings, shaft realigned, etc to the tune of $2,300. I called Hunter who said sorry but the Hunter dealer had replaced factory seal so they assume no responsibility. They have never heard of a key failing. Hunter dealer is undecided if they need to help with this bill as of yet. I need to add that I had a knocking sound when I was on about a 15-18 degree tilt before problem happened regardless if I was sailing or motorsailing. Still is happening with new shaft & realignment. Would appreciate any comments/advice.
