Shaft coupling seems stuck to engine coupling on a flexible shaft coupling on beta marine 10
Oct 30, 2019
2
Recent lurker, first time post.My buddy and I are trying to replace the cutless bearing in our 1976 Vega. First step is to remove the shaft. We loosened the set screws on the dripless seal and moved the collar forward. Then we removed the bolts on the flexible coupling to the engine. Looks like we got them all. Gave it a yank, but it was stuck so we put some PB blaster on it and waited a few days. Came back and it still won't budge.Is there something else we need to remove from the shaft? if not, how do you suppose we break the corrosion on the coupling? Drive a wedge? We try to flathead screwdriver and a chisel between the shaft coupling and the engine coupling to no avail. How cautious should we be about the pulling force or torsion we apply to the shaft? We're afraid to use a torch because of the rubber seal on the flexible coupling and because it is right by a bunch of wires.If there somebody listening today, it'd be great to talk to somebody on the phone who's done this before. We're working on it today. You can reach me at seven too seven, 644-9632, text or phone call is fine.
Nov 8, 2001
1,818
Need a photograph of prop and coupling then I can
advise. Original was a combi and variable pitch prop and shaft will not just
come out as per usual
Steve Birch
matt.broerman@... [AlbinVega]
Sent: Thursday, October 08, 2015 3:35 PM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Shaft coupling seems stuck to engine coupling
waited a few days. Came back and it still won't budge. Is there
This email has been checked for viruses by Avast antivirus software.
www.avast.com
