Shaft Coupling
I removed the coupling flange on the shaft in my 37C so I could install a new PSS Dripless shaft seal. It was very difficult. The process involves removing the existing bolts, separate the two mating flanges and inserting a spacer (such as a socket), then using longer bolts pull the two mating flanges together. The spacer will push the shaft out of the flange. The two day process involved many iterations of tightening the bolts and hitting the flange with a hammer using very short strokes (due to space limitations). Also, due to space limitations, I had to use two or three sets of different sizes of bolts. At first progress is extremely slow, but gets better with time. Putting the flange back on the shaft was much easier. After lubricating both, just pushed it on by hand.
