C chusansail . Oct 5, 2008 26 hunter 37 cutter brunswick Oct 12, 2009 #1 I have a flexible coupling on the shaft. does it require a special procedure when aligning the shaft Last edited: Oct 13, 2009
Franklin . Jul 20, 2005 2,422 Whitby 55 Kemah, Tx Oct 13, 2009 #2 do not belive so. I think you line up the shaft without it and then put it in. It's suppose to be a little forgiving in slight mis-alignments.
