Randy S.
Well, progress has been made. Holding tank is almost installed, and I'm going to subscribe to the aerobic bacteria theory of eliminating odour. I have two 1" vent lines - one on either side of the boat to ensure the best possible cross ventilation. Because of the run lengths, I will probably add a fan to force air (draw it actually) through the tank, but for now I will try it unassisted. The downside to this is I won't be able to run one of those chemical "bullet" intake line deodorizer/critter killers (one of my heads will still be raw water). Apparently, they kill off the bacteria in the tank as well.One question though: how long does it take for these critters to effectively "neutralize" raw material. In all these discussions, I have assumed holding tank odour to be that old pongy smell associated with waste that has been around for a while, but fresh solid waste can be quite aromatic as well. My situation is a liveaboard one, where the waste will be pumped every few days as the tank fills. So will the aerobic bacteria get a chance to do it's thing? If not, then it seems that won't be a viable solution, and I'll have to resort to chemical deodorants.Thanks....Randy
