sewage backflow
Dan
I have sewage flowing back into the head when the boat heels. I assume that the joker valve is bad but the manufacturer said I need a vented loop between the tank and the head. Your thoughts would be appreciated.
Dec 2, 1997
8,962
- - LIttle Rock
Replace the joker valve.. and...
Replacing the joker valve will slow it down--might even stop it completely for a while..but it's not the permanent solution 'cuz a joker valve isn't supposed to prevent slow seepage, only a flood. There are two ways to actually cure the problem: 1. a loop--not necessarily vented, just an arch higher than tank contents can climb over--in the head discharge line 2. move the inlet fitting in the tank (which, thanks to a little doodad called a Uniseal, isn't that hard to do--and costs almost nothing...see it here: http://www.aussieglobe.com/uniseal2.htm) away from the hull toward the centerline of the boat...so that waste runs away from it when you're heeled to one side, the head discharge hose is running uphill when you're heeled to the other side. If you also spill waste out the vent when heeled, moving the vent fitting too will also solve that problem. IMO, #2 is the best solution.
Paul Badome
holding tank cleansing
Hi Peggy, this is a great site, anyway to find a place that professonally cleans a holding tank ? i keep using hot water and detergent , but its a slow [process and not really that thorough. So any places ouy there ? as usual your expert advixce will do Capt. Paul "" Columbia "" P30
