K
Kenny Chidester
Hello All,After years of being a power boater I have made the transition to sailing. I recently traded my Bayliner 22.5 Cuddy Cabin for a 1984 Macgregor 25. Now that I have a few hours on her I have started to notice some things that need looking at.1.Is there anywhere I can find how to properly rig the sheets (Main & Jib)to extend aft to the cockpit? The previous owner had no clue and I'm kinda learning as I go.2. It appears that one of the previous owners has replaced all the Boom to Mast mounting hardware and none of the hardware appears suited for the job. Where can I get a parts list of original hardware or upgraded hardware? Also the Main Mast mounting Boat is severly rusted and I would like to replace it.3. The Rudder seems very loose where it mounts with a lot of side to side play. Is it permissiable to install some kind of shims (Teflon maybe) between the Rudder and the housing? Or is this side to side play normal?4. This past weekend the Main Halyard broke and I need to replace it quick. Boat US and West Marine show the halyard to be 5/16 diameter is this the standard size? And looking for recommendations on the type halyard line to use. (I'm not racing, just cruising around).5. There has never been a name on this boat, and to appease the sailing Gods when I do officially name her, can anybody point me in the right direction on how to do it properly?These are just some of the questions I'm coming up with and any answers would be greatly appreciated. One last note, I've been out on her 5 times now with a total time on the water being around 20 hours. It sure is nice to know that I've only used around 1.5 gallons of gas as compared to 40 gallons in my old boat. This sailing thing is all right!K. ChidesterPort of Greers Ferry Lake, Arkansas
