Mark Johnson
I have a new (built 1999) Hunter which has the MaxGuard gel coat that supposedly does not need waxing. I'm not sure I'm buying that claim. What do you know about MaxGuard gel coat? I would like to use your products this spring, but have two questions...because the boat is so new, should I just clean the boat with soap and water then wax with Simply Brilliant superwax, or should I use the Sea Glow first then the Superwax? Look forward to your reply.
