I purchased a used hunter 22 last fall and am now getting it ready to sail. I have the following questions. 1. Bow Cap cover: The right(starboard) half of the fiberglass cap for on the top of the bow point is damaged and needs to be replaced. Is there anywhere I can buy one or will I have to make a new one? Fortunately, the part of the cap that is under the front shroud is ok, it is the just the right side that is broken.2. Cheek blocks for Jib: both my cheek blocks for the jib need to be replaced since the plastic pulleys is broken. Can I just replace the pulleys or the whole block?3. Two sheave deck organizer: The pulleys or sheaves are broken and my question is if I remove the two screws(assuming they will come out) that hold the organizer to the deck, are there nuts behinds it and if so, how do I get get to them(nuts) I don't see any access from the ceiling in the cabin. Or do I cut an access hole in the cabin ceiling? 4. Cam Cleat: One of the cams on the Haliyard deck cam cleat is also broken and I have the same question about removing it and access to the nuts holding it to the deck.Any help would be appreciated. ThanksJim
