I recently purchased a 1977 Hunter 25.
1) There are no cleats amidships making any kind of spring lines difficult. If I add these, what kind of backing would I need. Can fiberglass handle large washers, or should I try and make larger backings? Should I expoxy the cleats or just marine adhesive?
2)Some cracking of various corners and edges of the fiberglass.....filler or something else?
3)I might wet-store the boat this year thinking I'll want to use it (Chesapeake) good/bad idea? I can service the outboard (oil/lube/plug etc) should I do more than that if I'm going to run it at least 1 a month?
4) Any maintenance needed on the roller furler (looks to be a few years old).
5) Should I pull batteries if they are again getting a good charge 1/month?
Thanks!
Thanks!
