Setting the mast strut lengths on H260
tomhn
Sep 10, 2024
1
Hunter 260 River Dart
Is there a correct way to set the length of the mast support struts on a H260? She is relatively new to me. When I first dropped the mast and detached from the mast foot, there was no way of re attaching to the mast foot as it was out of alignment. I adjusted the strut lengths while the mast was dropped to be able to realign, attach the mast foot and step the mast. I am concerned the struts are now under unnecessary tension (I had to make the both longer, one more than the other), should the lengths be set again when the mast is up and straight?
Aug 26, 2019
59
Hunter 260 Eau Claire
Mast struts: Hello Tomhn, were you able to successfully adjust the mast struts. I did not see any response from the forum. I have to reinstall the mast because I replaced the mast plate. Took a trip without the rig while waiting for the part so I have to reinstall everything.
