...yes, about that mast...
Video. Made me chuckle.
The mast raising--kinda' what I was fishing about for. I can't imagine that going well, and I had given up on the idea, but...?
My situation: I've been mostly sailing on some local lakes, and a protected harbour, where I can trailer onto ramps. Totally set the boat up (with sail down, rudder up, etc) on the trailer, as I'm sure most do. There is another area here, a semi protected ocean area, at Port San Luis, CA, by my house, that I'd like to sail, and assumed I could. The only way to put the boat in there is with a hoist. One day, weather's great, I take work off, and head out with the boat to Port San Luis. Ask hoist guys, about how it works with the mast up, do we just slip the boat a bit sideways if need be? "Nope, mast must be down, and you can take it over (I have a 2hp outboard) to the working dock and put it up there." A little 5x20 moored bit of dock next to the pier. That the seals like to hang out on. With all the tourist walking by looking down on it. Trying to set up the boat there would have MUCH potential for comedy. So I thought, I'll never be able to sail here. But then (danger, danger, danger) I started thinking about it...
I guess this is the way everybody elase does this, but, while on the trailer, I walk the mast up, take the halyard around and hook it to the front cleat, hop out, attach the halyard to the trailer winch to pull the mast forward, then attach the jib.
The "technical" showstopper (I'm not even going to discuss simply tripping, rocking, falling out the boat into the water) to doing this on the water, is the trailer winch. Could something portable replace that? Such as something that could be hooked to the bow loop and the halyard to pull it forward, then detached and stowed to sail?
So it could go something like this. Do everything I do as normal on the trailer, raise mast, but don't attach jib, leave mast up with halyard to cleat. Then attach boom and sail, just without halyard attached to sail. Then (if the boom pivot alows it to swing towrds mast enough), lower mast/boom/sail assembly back down, while still partially pinned at the hull, and a bit to the side for room to work outboard. Hoist down into water, motor to working dock, chase away sea lions, and then attempt to wobbly push back up a now heavier and more awkward mast/boom/sail, hold in place nimbly rocking with the swell, then hook halyard to cleat, attach home-made portable winch...finishing with aplause and great accolades from the growing crowd on the pier.
Or is that just crazy talk.
Tomorrow I think I'll head out to Morro Bay to sail (at a ramp) and give it a bit more thought while I set up there. If the boom pivots up enough, I could make something up to pull the mast/halyard forward with a cargo strap...
