Service/owners manual h23.5
D8758
Nov 18, 2006
3
Hunter 23.5 Lake Simcoe, Barrie, Ontario, Canada
Im a new owner of a 1996 hunter 23.5 and am in need of an owners manual. Since this is my first water ballast sailboat, i need some infomation on the operation of the water ballast, here goes: are the two inlet holes at the bottom of the hull , (behind the keel )controlled by seacocks?. How much water do i let into the hull? is there a specific fill level mark i should find or is this somehow self regulating?? Any info in this boat would be greatly appreciated. I had hoped to download the service manual from the hunter marine website but couldnt find the link if there is one thanks
Dalton
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Under bottom stair is a large wing nut and plug.open nut and plug at launch,water ballast will fill.After close nut and replace plug.No adjustment on water level.At retrieval with boat on trailer open nut emptying ballast.I leave mine part open so no chance of freezing up north.If you cant find manual,Ill be glad to copy mine and send to you.I see on your Bio you had a C 20 ,still have mine .Its a 78 one owner.Great boat.
D8758
Nov 18, 2006
3
Thanks for the info DJN51, would greatly appreciate a copy of your manual, I am looking forward to the new experience of sailing my first waterballast, from all i hear the h23.5 is quite a boat. email: dalpldev@rogers.com. address Dalton Alleyne, 57 Neelands Street, Barrie Ontario, L4N 7A2. again Thanks.
