Trailer trials
I have a '94 h26 with trailer bought used from a dealer. They thought they acquired the trailer new but had no papers, Hunter lost the papers in a flood. It was a real bear to title it in N.Y. Had to get letters from Hunter and the broker stating the origional paper work lost and that the broker owned it. Believe it or not, the trailer was titled as new since it was never sold. For some reason the vin was only 16 letters/numbers when the U.S. standard is 17, but they titled it anyway. I saw a '95 Hunter trailer for a h26. It had a rivited plate with the vin on it. It also had a stamped vin grinded off where Ray's and my trailer have it stamped into the metal. So, It is possible that your trailer had such a plate that fell or was pulled off. Davor's suggestion is a viable alternative and almost the route I had to go. Your state will assign a vin to a homemade unit. You will probably need to get it officially wieghed Contact your states DMV if the vin is not on the registration or you can't produce a proper paper trail. alan
