serial number /Crazy Dave
Sep 25, 1999
600
Hunter 23.5 Indian Lake
If a hunter sailboat has the ending digits 94 does that have anything to do with the year it was made? Model year ?Thanks Mike
Jan 18, 2014
238
Hunter 260 Palm Coast, FL
Serial number
It means model year 1994.
Here what I found but the credit goes to Kobernus. I hope he doesn't mind. Many good information on his site: http://kobernus.com/hunter260/hin/HIN.html
Here's an example for a 2003 Hunter 260, hull number HUNF0296A303
HUN – The U.S. Coast Guard assigns each boat builder a 3-letter identification code and keeps this in a Manufacturers Identification Code (MIC) Database. Information on this code can be found on the U.S. Coast Guard boating safety site:http://www.uscgboating.org/regulations/boatbuilder_s_handbook/part_1_c.aspx
(I replaced his link, which did not work)
F0296 – The 5 digit hull serial numbers are next. This series of numbers and letters, assigned by the manufacturer, must be unique to the boat.
A – This is the month the hull was manufactured. Each of the 12 months is represented by a letter starting with A. In our example, "A" means this boat was manufactured in January. "L" would be a boat made in December.
3 – Year of certification or manufacture.
03 – Designates the model year. In this case the boat is from the Hunters 2003 model year.
Sep 25, 1999
600
Re: Serial number
I am looking at a hunter that was advertised and a 1993 but the number I copied off of the title for insurance is . H394/ the last four digits , .I did not compare it to the actual number stamped into the boat it self .
Dec 16, 2006
353
Hunter 25.5 Cayuga Lake, NY
Sounds about right to me! Hull laided up in August of 1993 and used to build a 1994 vessel. I would look at the title for the vessel for confirmation.
Just look at the auto industry. A vehicle purchased today was designed 2-3 years ago and built last year. That's how you can purchase the next year's model in the fall.
Dec 2, 1999
15,184
Surveyors normally do a tracing of the HIN when doing a survey.
203
Nov 5, 2013
73
Hunter 22 1983 Lake Norman
Re: Serial number
In the FO296 example above, what number would appear on the sail?
I'm familiar with Highlanders and Lasers, and they all have a hull number that appears on the sail. On the Lasers, it's sorted out of a series of letters and numbers like the Hunter example. On the Highlanders, the hull number is drilled into the floor of the boat below the tiller... as well as on the hull.. but I've never looked at the hull ( standard ) location cause it was so easy to see it where the skipper stands (c:
-na -NA Anywhere USA
MMsailor;
HUNF0296A303
HUN- Manufacturer or Hunter in this case
F- Model of the boat or in this case referrers to the 260
0296- Referes to the actual Hull number of 296
A- Stands for the month or in this case January when the hull was laid
3- Stands for the year the hull was laid
03 Stands for the model year
I hope this helps you sir. FYI, Hunter starts their new model year at the beginning of August 1. For example, model year 2014 began effective the hull laid as of or after August 1, 2013.
Crazy dave condon
203
Nov 5, 2013
73
Now I know what numbers to put on my new sail (C: Thanks
Sep 25, 1999
600
MMsailor;
HUNF0296A303
Crazy dave condon
huna2502h394 would indicate a hull laid in 93 and model year 94 ?
Correct for August of 1993 as H stands for the eight letter for the month of August in 1993 for the model year of 1994 beginning as of August 1, 1993 for the model year 1994.
crazy dave
