Separating mixing elbow from exhaust
Dubo
Oct 26, 2010
86
Hunter 340 Deltaville Va
I read several good post regarding mixing elbow. I have a yanmar 2gm20f and i would like to inspect its elbow however once I remove the two clamps it seems the exhaust hose is frozen to the elbow. None of the posts here mention any trouble breaking the exhaust hose free. Is there a method to loosening the exhaust hose? PB Blaster, heat or brute force? I'd rather not destroy the hose since it look fairly solid and is wire reinforced.
Thanks!
Dubo
2,362
I run a screw driver between the hose and elbow to break it free. After, I coat the elbow with anti-seize compound before installing the hose. Make sure hose clamps are adequately tight.
Hunter 37 C sloop Punta Gorda FL
There are tools for loosening hoses. Look like an ice pick with a 90 bend near the end. Try NAPA, Auto Zone or whoever you have for automotive tools
Dubo
Oct 26, 2010
86
I wasn't planning on removing the elbow but that does seem to allow you to get a twist on the connection which would probably be a good thing. I will also see what that tool is about at the auto shop that Bill mentioned.
Thanks for your clues...I'm off to cut up my knuckles!
Dubo
Oct 10, 2008
277
Catalina 445 Yorktown
Try a hair dryer to warm up the rubber. After its warm, use a large screw driver to work the hose off.
