Sensor Plug reinstallation
5
- - Cave Run Lake
I am new to boat ownership and need to clean and reinstall the depth and speed thru-hull sensors. Other than cleaning the edges of the plugs and the hull hole, what else should be done? Is there any special material I should use to ensure a good seal? I don't know if it matters, but . . . My boat is a 1984 Catlina 25. Thanks
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
C25
If you are new to the C25, you should go to and use the C25/C250 forum. It is one of the biggest and best: http://www.catalina25-250.org/forum/
