W
Walt G.
My 37c is powered by a salt-water-cooled Yanmar 3QM30 fitted with an aftermarket Sen-Dure fresh water conversion system. The heat exchanger failed last week, so now I've got a salt-water cooled system again. In looking around for an exact replacement for the Sen-Dure exchanger (it's a horizontal tube 2 inches in diameter and 22 inches long with four 5/8 inch inlets/outlets for fresh and salt water, and a 4 inch vertical tube at one end where the pressure cap sits.) I got a quote of more than $700 for a replacement. So I'm looking at alternatives.If any of you have had luck with less expensive generic units on a 3QM30 or similar engine, I'd appreciate a reply. Also, if you know of other sources of supply, new or used. Universal makes a vertical unit, model 300118, that looks as if it might work -- anyone have any experience with this unit? (Only $185 from Boatman's I-Net Marine). Thanks. Capt Walt
