I read a article in "Small Sailboat Advisory" mag.This guy had built a plywood boat and was telling a story of a fine day on the water with it. (makes me jealous cuz I'm on dry land and it's winter here in N.E.Pa)!
On it boat was a self tending jib.
Being ever courious, I went to U tube and typed in "Self Tending Jib". (you be surprised what you can learn from U tube, I learned quite a bit as a "newbie").
Low and behold there is was!
A jib with a track, as you tack (or I guess jibe) the jib slides from side to side on a traveler.
Looks easy enough?
1. Is there a special track?
2. Does this system work well?
3. Can any jib be set up this way or ??
4 what do you do when your runnin with the wind?
I've only been doing this for a year and I've already found that I'm a "sheet tinker". I always seem to be playing with this sheet or that to see if I can get a fuller sail, a bit more speed, what will happen, etc. so I dunno if I can "leave well enough alone" with it, but it sure looks like a cool set up.
Joe
So much to learn! You think the goverment will pay me to sail full time? A "Sailing Grant"?
Looks easy enough?
Joe
