Selden Rodkicker strut replacement
Jan 27, 2019
19
Hunter 36 San Diego
I have a 2005 H36 and during a recent repair discovered the Rodkicker from Selden had no gas strut inside. Apparently this was an option from Selden. I'm curious if my boat is a "standard" Hunter build without the gas strut or if it was removed by PO.
Thanks for any insight!
Mar 20, 2004
1,746
I'm pretty sure Hunter never installed the optional gas strut unless it was ordered by the original purchaser. My dealer never mentioned it when I ordered Escape
May 7, 2012
1,567
Hunter e33 Maple Bay, BC
Common for it to be shipped without a gas spring. My 2012 Hunter e33 shipped new without. I’m sure the SBO store can give a quote if you specify the Type (probably Type 20) and normal, hard or super gas spring. They are very functional replacing the topping lift but Selden’s are pricey. I understand that other reputable manufacturers sell for far less and are of equal or superior in quality.
292
Hunter 41AC 0 Portland, OR
My post about installing a generic gas spring may be useful:
Jul 27, 2011
5,134
Bavaria 38E Alamitos Bay
My aftermarket gas spring failed at about 20 yr. My rigger/Selden distributor who helped me acquire a replacement and install it said the Selden gas spring would not have failed. But, 20 yr? That’s still a pretty good run.
225
Hunter 41 Longport,NJ
Given the cost of the Selden replacement - 20 years for an aftermarket spring sounds pretty good to me. Thats correct - it is optional equipment'
-na -NA Anywhere USA
@chuckwayne is correct for most of the Hunters never came with gas strut vangs as some of my customers wanted gas vs spring loaded struts. Former dealer now retired. Hunter did enjoy my homemade peach brandy made in Franklin County, VA but it was legal as no one had to pay. Some of you call that grog. Another name was moonshine. Statute of Limitations ran out a long time ago
Likes: Ward H
Aug 28, 2006
578
Bavaria 35E seattle
My Selden gas strut gave up the ghost after 22 years this past fall. I bought a replacement with a similar load factor from McMaster Carr for a much better price than the original German ones that are used. It fit perfectly and shipping was fast.
