Seized fuel deck fitting
Sep 3, 2013
22
bennetau first 310 stockton
Busy weekend on the boat...one more problem. Anybody have any success opening the deck fittings for fuel/water/waste once they have seized? Any suppliers other than Benetau? I have faithfully covered them with Vaseline but it didn't help for long...thanks!
Jan 6, 2014
35
Oceanis 351 Helsinki
I had a same problem with water fittings once. Just use a winch handle and hit it with hammer. After 5-10 hits, fittings opened.
Beneteau 323 Annapolis MD
I helped a neighbor with his. He cut the handle off a winch handle, put about a 24-inch pipe on it for leverage. It came out. I held it down into the socket while he muscled it loose.
Sep 19, 2010
48
Beneteau 41 Deltaville, VA
Replacement fittings from Beneteau are now SS instead of aluminum, so they don't seize and they aren't very expensive.
Mar 26, 2011
4,010
Corsair F-24 MK I Deale, MD
Lacking corrosion inhibitors, Vasoline is not really a very good choice for anything outside the medicine cabinet. This is kind of obvious, but the myth just won't die. Green Grease by Omni Lubes has tested many times better.
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
I had same problem when I brought new boat home..... both waste caps would not budge and to top it off, prior owner looks like he had same issues and fitting was stripping. I tried and they would not budge. Supplier wanted 85 for just the original cap and 180 for entire fitting. Went to West Marine and replaced both with stainless fittings for much cheaper. They look nicer as well. I keep them all coated with Teflon grease. Good luck!
Sep 19, 2010
48
Yes, the Amiot supplier's prices are outrageous, but you can actually get the entire fitting from Beneteau for about $55.
JRacer
Aug 9, 2011
1,407
Wish I'd realized that before getting the caps from Rig-Rite. Yes, they were spendy!
NYSail
Jan 6, 2006
3,187
The ss look much better and will last longer and still were less expensive than ambiot fittings. Now just want to preserve last ones (3) so they don’t seize at the wrong time.......
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Interesting. Is it corrosion of the threads that is causing the caps to seize?
I would imagine Tef-Gel to be the best thing to put on the threads. A very small amount, just enough to make a film on the threads, is all that should be needed. The stuff is incredibly tenacious, it sticks to surfaces and is tough to clean off. I do not imagine it is an issue, at all, for the fresh water tank caps.
Stainless is not always a bargain, either, since stainless steel threads can gall, making them seize, too. Same treatment, Tef-Gel, should prevent it.
And don't tighten, just screw them in enough to make the "O"-ring seal.
...Now just want to preserve last ones (3) so they don’t seize at the wrong time.......
USE them! Once a year I send an email to my condo group to "exercise" their under-sink shutoffs. Me, I never saw the one that goes to the dish washer, so it was frozen. $80 to replace by plumber.
NYSail
Jan 6, 2006
3,187
Yea coat them with Teflon grease..... it’s the salt water and aluminum. Have to bring it down to the o-ring for the fuel fitting otherwise water will get in.
Sep 19, 2010
48
I'm not sure I'd want to use Tef-gel on the caps for potable water tanks after checking the Material Safety Data Sheet for it. Yes, any amount that got into the tank would be highly diluted, but still... Lanocote is probably a better option.
When we bought our boat we found the waste fitting was completely seized the first time we tried to do a pump-out. And I recalled then that we found the y-valve was in the "overboard" position when the boat was surveyed, so I suspect the previous owner hadn't used the tank for at least a couple of years. The caps for the water tanks and fuel get used enough that they haven't caused any problems so far.
jviss
Feb 5, 2004
7,090
"Any amount" is not going to get into the tank.
