I had a Seidelmann 299
I owned a 1979 Seidelmann 299 from 1995 to 2001, when I sold it to buy a 1991 Hunter Legend 37.5, because we needed something that would take us further and in greater confort for much longer periods of time. I love our Hunter, but let me get back to the Seidelmann.The Seidelmann 299 sailed like a dream and for a boat just shy of 30ft it was roomy. I had no problems with the boat structurally or mechanically. It passed two surveys five years apart with glowing marks--some very little water penetration of the deck near the winches, which was solved by simply rebedding them. The rest of the deck was dry a solid, as was the hull. It was a bit underpowered by today's standards, but not in its day. The gelcoat haad lost its luster beyond what compunding and polishing could bring back. We had a two-part polyurathane paint job professionally done, and she looked like new. We also replaced the original sails with a new set.One slight peculiarity about the boat. She finds her grove going upwind at about 22 degrees of heel, which make for too thrilling a ride for some of our passengers, and the nast can start to pump sometimes in a real blow, if you have shortened sail enough. (I met someone who solved the lastter problem by installing a babystay. If you do this, however, make sure that on the underside of the deck the babystay is anchored to a bluck head.In all, no complaints and would highly recommend a Seidelmann 299 to anyone. I did not know of as Seidelmann 24.4. Is it roughl the same a the Seidelmann 25 (which incidentally I have seen and looked like an exact scaled down replica of our 299). Jack
