Greasing the Lockdown Bolt
Jon: My C-22 would definately take water into the compartment with the Keel Lockdown Bolt if I didn't grease it. I buy a grease stick at the hardware store, and coat the threads and screw it in. Then, I wipe off the excess. The grease is thick, almost waxy like a crayon, but a little stickier. The grease stick with teflon is actually the best, although for this bolt, the teflon isn't really required. Actually, I built up a fillet with silicone before doing the greasing, then when I screw the greased bolt in, the excess grease fills the inside of the silicone, and seals the bolt even better. This has worked well for me for many years. Your C-22 should be dry inside, unless you have a leak. I do remember reading on this forum about someone with a new style C-22 who had a leak at the rubrail seam. But, if you aren't heeling your boat to the rubrail, you shouldn't be having that problem. Finding leaks is challenging, but eventually you will find them. I think that finding them on houses is actually trickier for me, because I keep telling myself that water couldn't possibly be coming from one place and leaking at another.I hope that you enjoy your C-22 as much as we have enjoyed ours. We bought it new 27 years ago and enjoy it now as much as ever.Aldo
