Seeking tips on spinnaker sailing
Scott Blahnik
I'm new to sailing with a spinnaker. This past weekend, I had my new asymetrical up with the wife and son aboard and experienced a rather unpleasant incident. I was cruising down river with the chute up without any other sails, and looking really good I might add. When I got to the mouth of the river and took the turn to starboard where the channel is all hell broke loose! A gust of wind about caused the bow to submerge. Well, it almost seemed like it. My first instinct was to douse it with the sock, which I quickly found out was a useless maneuver. What happened next was another gust of wind caused me to jibe right out of the channel...well, I'm barking out commands to my horrified crew, such as crank up the diesel and try turning into the wind...what we found out was it was hard to negotiate while going aground especially with that darn sail up. It only seemed to get worse. The cheap clip I had on the clew gave way and somehow the whole line went off like a flying snake and now I have a flapping monster on my hands which almost seemed to be coming after me in revenge. I'm hitting the deck and seriously contemplating a change in hobbies, such as something safer like sky diving! While in this position, flat on my stomach, it occurs to me to just release the halyard, which I did promptly, and pulled it down, and laid on top of it. Anyway, it was an adventure I suppose. Now I'm afraid I'll be gun-shy about using it next time.
Bill O'Donovan
Good experience
You broached, which is indeed frightening. Had the main been up, it probably would have absorbed the brunt of the gust and prevented the broach. You'll recover just fine. As for the family, remind them (1) it was just noise, nothing dangerous, (2) it only lasted a minute, (3) you brilliantly solved the problem by releasing the halyard. In retrospect, the last sounds infinitely simple but you'd be amazed at how many people overlook the obvious. Here's my short list for next time. 1. Turn downwind before raising the chute. 2. Make sure you're running offwind okay. 3. Push the mainsail out to 45 degrees or so. 4. Tell the crew what steps are coming. 5. Keep any signals and orders simple. 6. Be sure the spin sheet at clew has no impediments such as lifelines. 7. After raising the halyard, do the tack next. 8. Be careful not to get "in the lee," and gybe. 9. Douse the chute sooner than later, for safety. 10. Be proud that you look terrific! For more, go to the Archives on this site, type in the word "spinnaker," un-check Title, check Message, and voila! 382 postings will give you wonderful research material by real-world sailors who have made every mistake so that you won't.
G
Guest
Sailnet Article
Check out the article on Sailnet on flying an asymetrical spinnaker (see link below) BobM
Scott Blahnik
Thanks
Bill, you took it easy on me, and I'm already looking forward to my next adventure, me against the beast!
Butch Berchem
Kite sailing
You might have better luck if when using your spinnaker if you raise and lower it behind the jib. Go deep enough to blanket the kite and lift the dousing sock roll in the jib and inflate the kite. Reverse the steps to douse. Good luck
