V
Victor Robert
A few months ago I opened a floor panel on my Hunter Passage 42 to find the water level was only a few inches below the floor boards (yes, that sinking feeling). The problem was a failed bilge pump switch - the traditional Rule mercury float type. Having never failed before, I hadn't given the pump switches much thought. In shopping for a new one I was surprised to see manufacturers' proudly offering a '2 Year Warranty'. This is a device that is intended to keep my investment on top of the water instead of under it and its only designed and built to last two years ??? The other concern I had in looking at the old switch was the wisdom of a design which places a hot wire perpetually in the water.I found the solution at West Marine. An electronic switch that is mounted entirely above the water and activates when the water rises to touch a sensor on the bottom of the plastic case. And a lifetime warranty ! Perfect, problem solved !Last week I again lifted a floor board looking for something and - you guessed it - that sinking feeling. The new switch had failed in the ON state, thereby burning out the pump by running it dry for who knows how long. Now I have a failed $40 switch with a lifetime warranty that killed an $85 pump on its way out and a boat without its primary protection against sinking.There has to be a better way. Comments PLEASE !!!
