I have use cotter pins and split rins to make sure my turnbuckles don't turn once the rig is turned. It seems to me wire ties would the job with less hassle. Thoughts?
Plus there are no sharp edges to snag clothing and skin if you get too close.To the OP, if you don't plan on adjusting them, use the rings. They are the most secure and best set-and-forget solution.
My dad used to say, "Don't sweat the small stuff."
I have been using aviation type stainless steel 0.040" safety wire for about ten years now. It's very easy to install with a twist tool and just as easy to remove with a wire snip. It's also good stuff to have on board for all sorts of temporary repairs.I have use cotter pins and split rins to make sure my turnbuckles don't turn once the rig is turned. It seems to me wire ties would the job with less hassle. Thoughts?
Mike...what twist tool are you using?I have been using aviation type stainless steel 0.040" safety wire for about ten years now. It's very easy to install with a twist tool and just as easy to remove with a wire snip. It's also good stuff to have on board for all sorts of temporary repairs.
I found a spool of SS wire at Lowes a few years ago. I was going to secure all of my shackle pins but never go around to it. I use the black zip-ties on my turn buckles and cover them with red (port) and green (starboard) electric tape. The color code helps my less nautical friends keep it straight. twofer.I have been using aviation type stainless steel 0.040" safety wire for about ten years now. It's very easy to install with a twist tool and just as easy to remove with a wire snip. It's also good stuff to have on board for all sorts of temporary repairs.
try here http://www.amazon.com/piece-AIRCRAFT-RACING-SAFETY-PLIERS/dp/B000YPL6POMost of those twist tools in this list do not handle .040 wire which Mike said he was using, thus the specific question.
