securing mainsail tack?
24
hunter 23.5 soton
Just bought an old 23.5 hunter. What is the recommended shackle/method to secure the mainsail tack? On other boats a 6mm twisted shackle would go through the tack eye and secure to the hole on the goose neck but the hole there wont take a 6mm shackle?
Dec 2, 1999
15,184
If you contact the spar mfg (or someone that sells the parts), they can usually supply replacement parts.
I suggest you start with Rigrite.
www.rigrite.com
Jun 6, 2013
24
hunter 23.5 soton
thks for the reply. The goose neck on the mast has a horizontal hole and a large bulls eye (W shaped metal) threads through it presenting 2 lugs 1 either side of the goose neck. I guess you just tie the reefing line or a cord through the mainsail tack to the lugs.
Jul 1, 2010
990
Catalina 350 Port Huron
