securing main halyard on in-mast furling
llogue
Mar 18, 2006
12
Hunter 33 Erie, PA
We have an in-mast furling main. What is the best way to secure the halyard during winter storage so it does not slap the mast? How does one attach a tracer line if that is the only thing to do?
Mar 20, 2004
1,753
winter halyard storage
we attach a 3/16 nylon line to the halyard-thru the eye- and haul it up to thte masthead so all but the shackle end is protected inside the mast. the light lines for all of our halyards are brought forward and tightly wrapped around the forestay so they don't slap or chafe. in the spring, we bring the halyard down, inspect, wash, and use. If the halyard end were damaged, I'd cut it off and resplice. the halyard could also be swapped end for end if there's significant wear, since the tail really isn't used after the sail is up.
Bill O'Donovan
tracer line
Sew the two ends together using fishing line. Works magnificently.
llogue
Mar 18, 2006
12
Hunter 33 Erie, PA
Size of line
What strength fishing line do you use and what do you use for tracer line?
