Securing cap shroud to spreader?
May 9, 2011
1,000
Hi Guys. Looking at my Vega, it looks as if the cap shroud is prevented from falling out of the groove on the end of the spreader if the rig becomes loose by nothing more then a "T" shaped plastic boot. Is this the normal way for a Vega or should wire seizing be used also? Cheers - Jeff.
Sep 13, 2002
203
There should be a strip of stainless steel around the shroud, fastened with a bolt through the spreader. I know it only too well as it made fitting new plastic boots a pain earlier in the year.
Alisdair
May 9, 2011
1,000
Thanks for the info Alsidair. The strips appear to have been long gone from
the end in that case. You've confirmed, however, that something other then
the boot is needed. I've already thrown the stick back up so I'll have to
send the wife up to to some wire instead. Cheers - Jeff.
May 12, 2009
57
Hello all,
I had the strip come off this summer and the cap shroud become unhooked from the groove. Had to get up the mast and re-secure temporarily. I guess I'll get someone to fabricate a new strip
when the mast comes down for winter.
Mikko Airaksinen
Albin Vega 1005 Ikiturso
