Securing Batteries on my H34
Nov 13, 2020
89
Hunter H34 Chesapeake Bay
I'm planning to install battery boxes and looking for ideas and opinions. I'll keep the batteries in the starboard cockpit locker by the fuel tank. My plan is to first replace the plywood a PO installed under the batteries, then secure the battery box straps to the plywood. I need a good method for securing the plywood down to the fiberglass. Will wood screws suffice?
Thanks.
Nov 13, 2020
89
Yes. You can attach the battery box to the plywood with screws.
Thanks, but that is not what I'm asking. I'm asking about attaching the plywood to the fiber glass. I would never secure the battery boxes to the plywood with screws. That would put holes in the boxes and allow any battery spillage to leak out. I will attach the battery box strap bindings to the plywood with screws.
dmax
Jul 29, 2018
1,224
Telstar 28 Buzzards Bay
Screwing into solid fiberglass is ok for light loads - I don't think batteries qualify as a light load. If you are unable to through-bolt, you could overdrill the holes, fill with epoxy and drill and tap some threads in the epoxy for some bolts or, if you have the height, epoxy some hardwood strips to the fiberglass and screw the plywood into the strips.
You could use thickened epoxy to adhere the plywood to the fiberglass. You could also consider just putting the batteries directly on the hull, depending on the surface shape.
For the tie downs, consider Maine Sail’s advice in the Mounting section of
Nov 13, 2020
89
Thanks. Good thoughts. I may test putting some wood screws into the fiber glass and see if it holds.
May 24, 2004
7,179
CC 30 South Florida
You could do screws in conjunction with epoxy if there is adequate surface area to adhere to.
Jan 24, 2017
671
Hunter 34 Toms River Nj
not 100% sure but I believe hunter originally used spry high density foam. Cleaned hull and used marine plywood, drilled hole thru plywood and leveled it, then sprayed the foam thru the hole in plywood until it squeezed out of the sides. Don’t know it that is the best way, however I believe that was how the factory did it. The foam is the same foam used around the sides of the icebox. Looks just like the can of stif stuff spray foam to fill door jams, sold at Lowes and Home Depot.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
The best battery tie-down solution I ever saw was on a Nonsuch 36. The had vertical threaded rods secured to the pan, and machined G10 FRP blocks that fit across the top of the batts with holes for the rods, and washers and wingnuts securing the G10 blocks. This boat could roll and those batts were going nowhere!
Jan 24, 2017
671
WasabiRush,
If you have not installed the boxes yet, now would be a great time to try to relocate them to the aft port side locker. This as I understand we’ll help with the starboard list that all h34 are plagued with. Moving the batteries to the aft locker also will make servicing them so much easier then climbing into the starboard dungeon that they are located in currently. This has been on my to do list for 38 years.
Nov 13, 2020
89
Are you saying that what appears to be the fiber glass base is actually fiber glass over plywood?
Nov 13, 2020
89
WasabiRush,
I have seen some re-purpose a portion of the aft berth for the batteries. I'm not ready to give up that space. :)
Jan 24, 2017
671
I have not been in the dungeon in awhile but as I recall the batteries sit on a plywood shelf that might be laminated with Formica along side of the fiberglass fuel tank well that the fuel tank sets in
I believe that battery shelf is part of the ice box counter top that extends thru the bulkhead and if my memory is. Correct spray foam fills the hull contour and secures it to the hull and also acts as support. Again I believe that on my boat some of the foam has squeezed out along the side.
the shelf is not fiberglassed over.
my battery boxes are lose and I screwed battery hold down straps directly into the shelf. The tie down straps I used don’t really work well, vibrations from the engine I believe causes them to constantly become lose, again this is another reason why it’s on my to do list to move to the aft locker. If I were to do straps again I would look into a small ratchet type instead of the buckle type at west marine.
