E
Eric Lorgus
I have a Yanmar 2GM20F on my 87H285. In the summer, this engine starts almost instantly -- she never takes more than one second of cranking. Before cranking, I advance the throttle to full, back to idle, and then set it at about 1/4 throttle for starting.But, in the cooler weather of fall (upper Chesapeake Bay), it's a different story. She cranks and cranks, sometimes catching a little, sometime with nothing. To go easy on the starter motor, I never crank for more than 10 seconds (and I keep the water inlet closed during all of this to avoid sucking sea water up the exhaust). I even try opening the compression levers and cranking her that way to get things stirred up. Even when I try having crew close the levers while cranking, she sputters that way, too.Eventually, she will start. It just takes a while. Are there any secrets out there I'm not aware of (excluding ether, which I don't believe in using). Should the throttle be open more or less? Eric Lorguss/v Explorer 87H285
