Well,
It's getting there... I'm changing the fuel filters on the 2 GM. The primary (on the motor) is no problem but on the wall of the engine compartment is a bronze colored secondary fuel filter about 3 1/2 inches roung and about 6 inches high that has the marking LST(O?) 7158 Marine Filter on it. The fuel line from the tank goes in one side and the other goets to the primary fuel filter on the engine so I'm sure it's a fuel filter. The name and number are casted into the case and a little hard to read.
I looks like the top of the unit screws off (not sure) as there is a little rectangular nub like for a wrench on the top. It did not yeld to some moderate tirning effort with a vice grip. The bottom has what looks like a small bowl with a screw on the bottom.
Does anyone out there in hunter land have any suggestions on how to service this filter? Is this a fuel filter and water seperator ? Dose the top screw off to change the element?
Any idea of the element (if there is one) brand and number?
Any help would be appreciated....
H- Nelson
H- Nelson
