Storm Jib
I will agree with the sail makers that by the time it is blowing hard enough to warrant installing as storm jib it will be quite a shore to lower a genoa. Pointing into the wind, unfurling it and lowering is much easier said than done with the wind blowing 40; not to mention the damage to the genoa from the violent lugging.Installing an inner stay requires further reinforcement of the deck for the attachment as it will experience considerable force in spite of its small area.I have considered a storm jib myself for such conditions and have concluded that it is one of the prices one pays for the convenience of roller furling the other 364 days of the year.If you are seriously thinking of sailing offshore on long passages where you will encounter long days of these heavy weather, then you may consider intalling a removable inner stay just for this purpose; in essence you will be converting your boat to a cutter. I will also add that boats for this type of ocean sailing usually also have running back stays. In any case you should consult with a yacht designer or Beneteau regarding the installaion and reinforcements required.If you think you may only rarely encounter these condtions then just sail on the main (presumable reefed) and turn the motor on for added push if necessary.RegardsEd
