A
Anthony Bavuso
I am considering some modifications to the way the second clew reefing line is rigged on my boat. At first my plan was to use only one clew reefing line. I would run the line through the first reef clew cringle and run that line back to the cockpit. I figured when I needed the second reef I would untie the first clew reefing line and re-run it through the second reef cringle. Well it only took one time when I needed the second reef to realize that once conditions got bad enough to need a second reef that you don't want to be trying to re-run the reefing line through the clew cringles.So I have come up with another plan. I will run both the first and second clew reefing lines to the cockpit but I will only run the first clew reefing line through the line clutch. As of the way things are rigged now without adding further rigging, I only have a cleat for one clew reef line or the other. So when I need to put in the first reef, it will be a simple matter of tightening the first clew reef and cleating it in the clutch. When I need the second reef, the first clew reefing line will have to be fed out of the line clutch and then the second clew reef line will have to fed in and then snugged down to put in the reef. This system gives me the benefit of both clew reefing lines run to the cockpit but only taking up the space of one line in the clutch. The only draw back is the hassle of feeding one line out and then feeding the other line in, but this surely beats trying to re-run the first clew reefing line through the second clew reef cringle!Any advice? Is this a good/bad idea? Comments? Thanks for all your help.
