My 28.5 has two batteries
Eric: I bought a used 87H285 that already had 2 batteries installed in the starboard lazarette. They're mounted on the sole, side by side. They're connected to a 1/2/both/off selector switch which is also mounted in the lazarette, on the closet bulkhead.I believe the 28.5's were built new with one battery, which was mounted under the galley sink.If you're concerned about weight and balance, keep the battery mount as close to the lazarette bulkhead as possible, which is itself just inches away from the prop shaft (cenerline).Instead of a selector switch, you might want to consider an isolator. These allow both batteries to be charged simultaneously, but when the charge source is removed, the batteries are isolated so that your house load can't discharge your cranking battery, should you forget to change the switch (which everybody does, sooner or later).Try visiting battmaxx@bytheshore.com for an example of an isolator. The good ones usually come with an override switch, so that if the cranking battery is discharged, the engine can be cranked from the house battery instead.Good luck.
