Second battery on a 1980 27'
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Anybody out there with a 27' have more than one battery on the boat? If so, where are they installed? Mine only had one group 27 battery when I bought it and it is under the quaterberth in the rear. I bought a battery box and a second group 27 battery today thinking I could mount it in the starboard lazarette next to the fuel tank but it does not fit... I can't seem to find a good place for the installation. Any ideas? Thanks, Manny
Benny
Manny, you can fit two batteries in the port side
quarter under the storm berth. Keep them together for shorter wiring connections.
A
Andy
Put them together if it will fit
The previous owner of our 82 H27 added a starting battery which sits outboard of the larger house battery. He contained it by strapping the two together. I have continued with this although I am not all that comfortable with the arrangement. If we did more than daysail or short cruises or had to deal with weather things would be changed. I am not sure how well a second large battery would fit in this area but there may be differences in available space here as there are elsewhere in various model years of the H27. Possible alternatives would be using quarterberth space or constructing a box in the starboard lazarette. Andy "Baroque"
Jan 22, 2003
744
Hunter 25_73-83 Burlington NJ
Locate and wire them together
Not only should they be located close together, but all advice I have received and discussed says they should be combined as one battery bank. This includes all of the benefits of having twice the battery power and is simpler and more reliable. The problem with wiring two batteries in parallel to double the amp-hours and keep them at 12 VDC is that the two batteries MUST be the same age and style and brand. They have to be as identical as reasonably possible or else one will emerge as the stronger of the species and wreak havoc on the other one. The charging levels will be determined by the strong one and the lesser/older one will never get fully charged, then begin to suck off the other one.... The short of it is that adding a second battery to the boat is the right opporunity to buy two new batteries at once, and then to replace them together 3 or 4 years on, and so on. Little Diana, which is a first-generation H-25 not unlike the H-27 inside, has two size-24 batteries under the after end of the settee berths, which is perfect for weight distribution. It's enough for about 3 full days on full battery power. I made the battery compartments using cheap WM-brand plastic battery boxes; they open with lift-out plywood panels (in fact, following nearly identically the Cherubini 44 practice!). They are wired together with 4-gauge wre passing under the floor and connected to a Blue Sea off/on battery switch mounted in the front panel of the quarter-berth. From there the electrical system and the rest of the boat thinks there is only one battery. I NEVER switch from one to the other-- that's only asking for trouble. JC
Manny
Oct 5, 2006
983
It looks a little too tight for two group 27's
I was hoping to contain the batteries in boxes but I guess I may not be able to. I try and measure again on Thursday when i get back down to the old girl. Thanks again, Manny
Jun 7, 2004
11
Hunter 25 Del Rio, Texas
I have 3 group 27's on my '82 H25
I put two under the port settees and a starter battery under the starboard settee, and slid them as far forward as possible. They are not in battery boxes, and are a pain to get to for servicing, but they are, I think, in the optimal position for weight distribution. I plan to install inspection hatches in the top of the settees so I can check the batteries more frequently without having to unclamp them & slide them out.
