ERICSON 25 SPECS
LOA 25' 5", LWL 21'10", Beam 9'3", Draft 4'11"(std)/3'11"(shoal),Displacment 5,000 lbs, Ballast 2,000 lbs, Sail area 341 sq.ft.25' is well finished and offers enough performance for racing. Bruce King design. Hull is solid hand layup. Molded fiberglass body pan is glassed to the inside of the hull, forming base for interior furniture and adding rigidity to hull. Deck, cockpit, and cabin trunk molding balsa cored, with plywood core under high stress areas, mast, and deck hardware. Exterior glass work is good quality, Gelcoat work is good. Deck has solid feel  due to cored construction.Deck hardware - stanchions, pulpits, cleats, and winches have adequate aluminum bearing plates. Design of the mast step to facilitate raising and lowering has greatly reduced bearing surface of the mast heel. Shroud chainplates are strongly tied to the hull. Navtec chainplates, shroud terminals and turnbuckles. No main boom topping lift.  Few boats of this size are used for long-distance cruising. The yanmar single cylinder diesel engine with a four knot cruising speed and fuel consumption of 1/4 gallon per hour could go 350 miles on the standard 20 gal aluminum tank. Small foredeck anchor well, no bow chocks. Single cockpit scupper 1 1/2" diam. recessed in a well at the back of the cockpit. For rough weather positive companionway locks will be necessary.Comfortable boat for extended coastal cruising for a couple. This is some info from one of my books, when they say coastal cruiser, its like a step back from ocean cruiser, or blue water cruiser. One other thing, the thru hulls are zytel valves, a reinforced plastic. Most have double clamped hoses, but the icebox drain has a single clamp. Plastic is immune to electrolysis, but cannot be overlooked.
