seaworthiness of 25
matt
i have sailed the chesapeake and wonder if i dare enter the ocean.? she is a 1983 with shoalkeel/6"centerboard. is she stable in the ocean? thanks!
David Hirtle
seaworthiness of the 25
Many years ago we took our between Block Island and Nantucket, MA. The weather was good, the sea state fair...she handled well....I would go too far off but if your boat is has the proper equipment, near coastal shouldn't be a problem.
Ben Allen
Coastal Sailing
Matt, I have a 85 O26, very similar to yours. We have taken our boat to the Gulf of Mexico and sailed between Pensacola, FL and Peridio Key, AL. We were several miles offshore and the boat performed perfectly. As with any boat in this range, check the weather first, and only go out in what you feel comfortable in. Ben Allen Montgomery, AL "Latte Dah" O'Day 26
Peter
Be careful offshore
Matt, With your O'Day 25 shoaldraft/CB, perhaps you've heard a "clunk....clunk....clunk" going downwind with a board that's not pulled up. That's your centerboard working back and forth in the trunk. Beating or reaching you won't hear it because lateral forces keep it pushed against the leeward side of the trunk. Now think of what would happen in a real blow offshore, with a heavy sea. Falling off waves, as will happen, is going to put some heavy, impulsive forces on that centerboard. It and its mounting hardware just is not made to stand up to such forces for long. For good reason passage-making boats were built (at least in the good old days of safe, seaworthy boats) with full, deep keels and attached rudders. Such boats could take a beating for days on end. I have a shoaldraft/CB O'Day 25 and would not think of taking it far offshore. If the weather forecasts are good and, otherwise, your boat is in good shape, going 20 miles or so offshore to, say, a Block Island or a Nantucket, is fine, and it's a lot of fun. You're not that far from a safe harbor if it turns gnarly. Don't think of going to Bermuda in it, though. Out in the blue water you're not going to find a safe harbor when it blows up. Peter
Brian
In calm conditions, go for it
I think you would be best off keeping the boat in protected waters unless you are confident the conditions won't be bad. As for my experience on an O'Day 25: In 3 foot chop and 15 knot winds, with the current tiller pilot, it rounds up often enough that I no longer would use the autopilot. In four foot chop and similar or stronger winds, the boat can be difficult to control at times due to round-up tendancy and it is a much more wild ride than a Catalina 25 I have some time in. I should add that in the rougher water I pulled up the centerboard because of my concerns. If the board was down the ride would probably have been a bit more stable, but not if the board failed from the high stresses placed on it. Brian
