Hi all,
Had an incident with the genset while running it the other day. It shut down due to an overheat and I thought it might be the impeller. I shut off the seacock and disconnected the hose at the raw water pump then opened it again holding the end below waterline in the bilge. Nada, so I tried blowing in the hose, nothing doing. Closing the seacock again I undid the hose at the strainer and repeated the check, nope plugged solid.
Fortunately MS was stopping by and I explained what I had while he looked at the water. Hmmmm, someone has to get wet? MS said "Get a coat hanger and we'll try the foot pump from the dingy". Plugging the air hose into the filter hose MS gave a few pumps and "Bam" the plug popped out of my external round strainer. Unbelieveable, a clump of seaweed floated behind the boat and I had full running sea water from the line. Reconnected and reset the genset, it all ran fine. Lesson for me, don't run the genset if there is seaweed in the water. ????? OK where can you find no seaweed in the ocean?
Thanks MS.
All U Get
Thanks MS.
All U Get
