So I purchased a 1 year old e33. After taking possession of the boat, I noticed water in the bilge. At first, I thought it was from the hose leading to the sink drain thru hull. The boat has 2 thru hulls, one for the sink drain, and the other for the head intake. When I did the inspection, the boat was on land, and both were green and somewhat corroded. I had asked that these be replaced.
however, the water in the bilge is sea water. I wet vac about 20 gallons a week out of the bilge(s). This is a lot, but doesn't show that way across multiple sections, maybe 1.5" of water.
I drained it all, dried it out, put out some newspaper strips, and it seems like it is coming from one of the keel bolts. I find that hard to believe, but seems the case. The inspection of the boat by the surveyor with me there showed no damage at all to the keel. The previous owner only had the boat 1 year, used a few times, I checked with the place he kept the boat and there were no repairs.
Just wondering if anyone else has seen this issue? My previous Beneteau never had a single drop of water in the bilge for 5 years.
Anyone else see anything like this? Do hunters accumulate water in the bilge?
